Line Lock ???
Old Jun 1, 2003 | 02:19 PM
96Z28man's Avatar
Line Lock ???
how difficult to install?
ALso, do they void any kind of warranty??
Can they cause any sort of damage???
Old Jun 1, 2003 | 11:51 PM
V6toZ28's Avatar
Not really ... you can get a complete kit from Thunder or TBryne for around $200, with everything you'll need and then some ...
... or you can get a Biondi solenoid and wiring kit from Summit for just under $50 and you'll still have parts left over. The only thing the Biondi doesn't supply - that you need - is the prebent brake lines. If you mount the solenoid in the right spot you only need one. Then take a coat hanger bend it into the shape you need for the other one as a template. Take to any brake shop and they will make it for you with the fittings for less than $10 ...
Dealer can make a case for you tampering with the brake system and void any brake work under warranty. Also a line lock is a fairly legitimate indicator of racing/abuse - read your warranty as to the specifics relative to racing ...
Not in and of itself ... but you will tend to to go through tires rather quickly ...
Good Luck
Old Jun 2, 2003 | 01:56 PM
96Z28man's Avatar
tks man
Fastbird93
Apr 9, 2016 07:01 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Jlo
Jun 24, 2015 11:54 AM
Pampered-Z
Apr 14, 2015 05:38 PM
