Knock coming from somewhere
Old Jul 9, 2002 | 12:09 AM
CW 99 Z's Avatar
Post Knock coming from somewhere
Ive only had this car about a month now and only drive it on the weekends but Ive noticed that when Im at a stop light with my foot on the brake i can feel a knocking coming through the brake pedal. I seems to do it worse with the AC on and seems to go away if i put it in neutral. It also seems to do it worse when the car is hot after driving around town. Any ideas what this could be? The only mods I have is a lid and flowmaster muffler BTW, its an A4
Old Jul 9, 2002 | 06:54 AM
Kwiksilverz28's Avatar
Post
Exhaust hitting the floor? Things are tight underneath and a lot of people don't get the pipes in perfect and they hit....
Old Jul 9, 2002 | 11:04 AM
CW 99 Z's Avatar
Post
I really dont think its the exhaust. I only had the muffler put in so the rest of the system hasnt moved. Also it did this before i had the muffler installed. This is not an audible thing. Its just someting you feel in the floor. My buddy felt it in the passenger side too. Any more ideas?
Old Jul 9, 2002 | 12:21 PM
Camaro ChriSS's Avatar
Post
There are common problems with the Idler pulley which runs the accessory belts making a lot of noise and causing unnnecessary vibrations. I'd let the delaer have a look at it. I'm guessing it's one of the small pulleys.
Old Jul 9, 2002 | 10:47 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by Camaro ChriSS:
There are common problems with the Idler pulley which runs the accessory belts making a lot of noise and causing unnnecessary vibrations. I'd let the delaer have a look at it. I'm guessing it's one of the small pulleys.</font>
Very true. I replaced mine at 35,000 miles. I need to figure out if you can just replace the bearing instead of the whole assembly so at 70,000 I can do it cheaper (I think it was $60)...
Old Jul 10, 2002 | 07:16 PM
CW 99 Z's Avatar
Post
thanks Ill check out the pullys this weekend
vb95z28conv
Jan 27, 2015 08:32 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
