internal difference 98-02
Old Feb 3, 2005 | 03:04 PM
kandied91z's Avatar
is there an internal difference between the years?
Old Feb 3, 2005 | 05:27 PM
MasterEvilAce's Avatar
Re: internal difference 98-02
98-99 (not sure about 2000) have more aggressive CAMs
(00?) 01-02 have less aggressive cam, but no EGR system (due to cam overlap)
You had a good chance of getting an LS6 heads and/or engine block, i believe it was towards the later years
those are all i know..
Old Feb 3, 2005 | 06:45 PM
DanBUCF's Avatar
01's seem to have a oil consumption issue...not sure if they tried new rings for that year or something??? I had mine replaced under manufacturers warranty due to excessive consumption.
Old Feb 4, 2005 | 01:40 AM
Cool Z's Avatar
NO F-body came with LS6 heads period!
Some 2001's and about 1 in 4 2002 F-bodies came with the LS6 block.
1998-2000 had a larger cam:198 intake / 209 exhaust duration @ .050" with both intake / exhaust lift being .498" on a 119.5 LSA. The 2001-2002 cam specs are 197 intake / 208 exhaust duration @ .050" with a .467 " intake / .479" exhaust lift on a 116 LSA.
2001-2002's seem to have a more reliable oil pump, and have stronger rod bolts.
In 4/01 GM changed the piston design (tightened piston to bore clearance) and added a polymer coating to the skirt to prevent scuffing. They also used tighter piston rings to prevent ring flutter for better oil control.
Later 2000 models thru 2002 came with 241 cylinder heads which appear to have smoother cast ports than the previous 853's.
2000-2002 had better flowing cast iron exhaust manifolds and higher flowing catalytic converters. The 1998-1999 cars used double wall stainless-steel manifolds.
1999 and 2000's had smaller fuel injectors than 1998's and 2001-2002's.
And of course all 2001-2002's came with the LS6 intake manifold.
Old Feb 4, 2005 | 06:24 AM
ok, intake manifold.. not heads
Old Feb 4, 2005 | 06:41 AM
psychocabbage's Avatar
Grrrr. While I understand everyone wanting to call the cam on the earlier cars "more aggressive" I would like to point out that the cam in the 01/02 cars was much more balanced. Unlike the 98-00 year model cams, the 01-02 cams have low end torque and continue pulling all the way to redline. I love my stock cam. Even if its not as "aggressive"! HAHA
Old Feb 4, 2005 | 07:13 PM
Plague's Avatar
how would you check if you had the LS6 block?
sorry
me<--- still learning fbody nub
Old Feb 5, 2005 | 05:48 AM
BirchMan98z's Avatar
I had no problem with low-end torque with my stock cam-- guess the people who complain don't drive well.
Old Feb 5, 2005 | 09:22 AM
Onez4u2bn's Avatar
I have an 01 and my dad B*#ches at me like it's my fault the car eats oil. Ive always wondered if it were just my car that did it. Seemed kind of weird. Did the rings make it better or no?
Xiantyl
Jul 21, 2015 05:42 AM
JCSWS6
Jul 19, 2015 06:47 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
SergheiS
Jul 5, 2015 03:27 AM
