installing headers....help
I'm installing my Jet Hot Headers right now and need some help. The passenger side slid up like butter!!!! I loved it.
Now onto the driver's side. I'm gonna have to make a notch in the K-memeber and maybe disconnect the steering linkage. But the header is also hitting the big suspension piece that the spindle and lower front control arm is mounted to. Looks kind of like a burger where the cheese sticks out around the whole bun, that is where it is welded together. I think I need to make a notch in it. My question is, is that safe to do??? also, the header bolts of the driver's side were shorter than the passenger side. And the new header bolts I got from Jet Hot are all the same length. Is this going to be a problem? |
I've heard of people having to notch the k-member when installing pacesetters but not the jet-hots. Are you sure you have it all lined up correctly. I don't know exactly where it needs to be notched on the pacesetter LT install, but I would guess the same area. I would say it's safe to notch it if it is absolutely necessary. I have not yet had the joy of installing headers on an f-body so I am only relaying what I have read about other installs. Maybe someone with personal experience can chime in and give their personal experience.
Every set of pacesetters (including my own) The K-member has needed to be notched. No worries about doing that, as for the other thing its hitting i can't think of what that could be. Try lowering the tranny a couple inches to see if it will give you enough room to get it up there. Make sure you use the stock metal gaskets and DO NOT use the paper ones they give you. Use your stock headers bolts too if you'd like. Tighten em from the middle out.
[i]Make sure you use the stock metal gaskets and DO NOT use the paper ones they give you. [/B] |
buy new metal gaskets from GM or thunder racing...they are the best ones.
check to see if the header is hitting part of the casting "ears" on the side of the block. i just installed my Flowtechs last nite, and one of the pieces from the casting of the block was in the way. it took 5 min with a hacksaw (gotta love alum) and it was off. header slid in without problem after that. sofar i havn't had to notch anything (unless you count that casting part), the K member is a bit close but i'll find out if it hits sat when i get it fired up. |
thanks guys. Its off to the garage now for day 2 of my install.
Me and my brother put jet hot long tubes on his 99 ss camaro
It doesn't matter that all the header bolts are the same it works fine, and by the way their is no need for any notching or cutting for that matter. Jet hot designed their headers perfect. Just make sure you get the car really high so you can fit the header in on the drivers side. You almost hace to stand the header on its end when you begin to put it on. The linkage has to be removed and a little peice with two bolts thats right beside the oil filter was aken off for a moment so I could get the header into place. Jet hot long tubes do not require any cutting or notching anywhere. That goes for the lt1 cars to because I have jet hots on my lt1. Sorry I didn't respond sooner |
Originally posted by T/A KID Jet hot long tubes do not require any cutting or notching anywhere. That goes for the lt1 cars to because I have jet hots on my lt1. |
Originally posted by T/A KID Me and my brother put jet hot long tubes on his 99 ss camaro It doesn't matter that all the header bolts are the same it works fine, and by the way their is no need for any notching or cutting for that matter. Jet hot designed their headers perfect. Just make sure you get the car really high so you can fit the header in on the drivers side. You almost hace to stand the header on its end when you begin to put it on. The linkage has to be removed and a little peice with two bolts thats right beside the oil filter was aken off for a moment so I could get the header into place. Jet hot long tubes do not require any cutting or notching anywhere. That goes for the lt1 cars to because I have jet hots on my lt1. Sorry I didn't respond sooner |
Now that I read this I'm gonna take a closer look but getting the driver header in was not the problem, it slipped in with the steering linkage remove. Problem was that the header was touching the K-member when I tightened it, and I had to do some trimming.
Well i had to disconnect the steering linkage and notch the k member (but not in the usual place, I'll post pics later.) Everything is done, and I'm gonna get a shower before I fire her up!
