installing Harland Sharp rocker arms
Old Jul 14, 2006 | 11:06 PM
maro z28's Avatar
I'm thinking about getting some Harland Sharp 1.8 rocker arms for my 2002 z28. I've got the full range of exhaust and intake bolt ons(lid,CAI,catback,LTs,3.73,tune,ported tb,vig2800)I'll be getting heads and a cam later. Will these rocker arms give me clearance issues on say a tr224? How easy are they to install? Are we talking taking off the valve covers and swap out, or is it more complicated? Any sites with install instructions? Will I need to tune to adjust for the increase in lift? Thanks
Old Jul 15, 2006 | 01:17 AM
Capn Pete's Avatar
Re: installing Harland Sharp rocker arms
^^^ valves?!?! That means pulling heads, dude! Pushrods and springs might not be a bad idea though.
But, what you need to know/find out (which hopefully someone can chime in with an answer) is whether a given aftermarket cam CAN or CANNOT be run with 1.8's. I know that most of Comp Cams grinds don't recommend use of 1.8 or higher ratios (that's just one that I know off the top of my head --- they state right below pretty much every camshaft they list for LSx engines). I'm sure there are some that can work with ratios above the stock 1.7 though.
Old Jul 15, 2006 | 08:43 AM
AL SS590 M6's Avatar
Moderator
Originally Posted by Taintedz28
while yur in there do valves pushrods and new springs, as for those other questions i cant help ya out. its fairly simple to my understanding though
Tainted will you please not post up answers when you clearly don't know what you're talking about.
To change rockers all you have to do is pull the valve covers and change them.
Changing to hardened pushrods at the same time is easy, just drop them in when the rockers are off.
To change valves you need to pull the heads.
To change valve springs you need special tools and a lot of time.
As far as a cam with the 1.8s you'd have to make sure that the cam will work without having piston to valve clearance issues.
Old Jul 15, 2006 | 11:26 AM
SSpdDmon's Avatar
Not only piston to valve clearance, but how steep the ramp rate is on the cam your buying. Running higher ratios on a really aggressive lobe can alter valetrain harmonics. It's better to run the rockers the cam was designed for to be safe. Crane has some pretty cool stuff out now with a variable rocker ratio setup designed to work with some of their cams. You should check out their site before you just up and pick something.
Old Jul 15, 2006 | 11:36 AM
teke184's Avatar
if you're planning a h/c setup down the road, the 1.8 rockers are a waste of time and money.
Old Jul 15, 2006 | 06:14 PM
Moderator
well excuse me lol. i jsut notice that sometimes its recommended when changing out rockers so I figured id psot that up there. but now since ive been corrected I learned a lil something
If we all learn something every day then everyone gains.
carl.froehlich
Mar 13, 2015 12:38 AM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
newby
Jul 25, 2002 03:22 PM
