Idle re-learning procedure...
...after installing 228R cam, I'm having idle issue's...I know that LS1 edit will slove all my issue's but I don't have that luxury right now (one one in the North West is good enough for one reason, yet) so now I have to adjust the idle screw..but I have to let the computer re-learn it the raised idle...any idea's
My car had to relearn idle when i reset the ECU. The first time i started it after the ecu reset it stalled out. It continued this RPM fluctuating for about 5 minutes and it almost stalls when you blip the throttle. after a few minutes though and a drive it relearned idle just fine. Just my 2 cents.
BTW, to reset the ECU check out installuniversity.com
autoxr166
Sep 25, 2015 04:21 PM
