i need a little help
You'll tend to get different responses, depending on who you ask. Basically, stock for stock, the LS1 has a little more power. Once you start modding, it's anyone's ballgame. The LT1 has been said to have a bit more low-end torque, and deeper exhaust note, but I don't know, personally. If I could go back, I might have looked for a cheaper LT1 car, but at the time, I just wanted a new car, so I opted for the first one I drove.. I was instantly hooked.
Good luck.
Good luck.
Well, the LS1's have quite a bit more power stock for stock and would spank an LT1. Also, there are some other upgraded areas, like brakes, etc. I think parts are a little cheaper for LT1's, but IMO the LS1 is a better car with more power and performance capabilities. I mean with just bolt-ons, heads, and cam, you got yourself an 11-second car. Actually, I have a friend who's got bolt-on's, cam, and 100-shot n2o, he goes 10.90's on n2o, and like 11.80's on motor and he's on stock heads.
It definitely has the advantage in the top-end range.
