I have the slowest cammed LS1 in this country
Old Jul 8, 2004 | 08:02 AM
6speedZ28's Avatar
Well I officially have the slowest cammed LS1 car in this country. I was consistent as hell, all of my runs were around a 13.75@ anywhere from 99-102mph. So after the cam I lost 2 tenths from my best and lost 1mph. I was fighting my Check Engine light all night for both random missfire and my TPS sensor is shot. I had a friend erase my codes twice with a Tech 2, the second time was right before we left and by the time I left the drag strip and pulled onto US41 to head home my light was back on again. Needless to say I am frustrated as hell. Needs a tune and some longtubes, but jesus it should have been faster than what it was!!!
***The track prep last night sucked, it was cool but the air was really thick and heavy, some people even complained about the fact that they thought the timing lights were off but I'm not sure about that***
Old Jul 8, 2004 | 08:32 AM
4U 2 NV's Avatar
bent pushrod maybe?
Old Jul 8, 2004 | 08:51 AM
6speedZ28's Avatar
Originally posted by 4U 2 NV
bent pushrod maybe?
Doubtful, just replaced them 1K miles ago when I did the cam swap, I went with hardened ones. The car has never been revved over a stock shift point and makes no noise when idling.
Old Jul 8, 2004 | 08:52 AM
PAGregSS's Avatar
Did you install the cam yourself? Did you get the timing chain back on correctly?
Old Jul 8, 2004 | 08:56 AM
6speedZ28's Avatar
I didn't do it but had a professional do it for me. I trust this person as he is a head mechanic for LG in Texas.
Old Jul 8, 2004 | 09:30 AM
V6toZ28's Avatar
"Engine light all night for both random missfire and my TPS sensor is shot."
The PCM uses the MAF, AIT and the TPS to set the fuel mixture ... throw in some misfires and you're pretty much in the crapper.
Also I don't see a TC in your sig. A stock TC is not going to be able to take advantage of cam and may even keep you out of the power band ...
Old Jul 8, 2004 | 10:45 AM
allmotorta's Avatar
I saw you run last night at 41... Yep, the air sucked. I only managed a 12.11 @ 118 in my Cobra with about 480rwhp
The track prep was garbage as well...
Old Jul 8, 2004 | 12:48 PM
6speedZ28's Avatar
Well **** if I would have known it was you I would have stopped by and said something. That was one hell of a race between you and my friend in his blue Z06...I think you edged him out in that one though. He was consitant in 12.0's most of the night and thats with 425rwp. He should have had 11's but couldn't get any traction.
Old Jul 8, 2004 | 01:39 PM
SSCamaro99_3's Avatar
I have run as poorly as 13.9 @ 110.6, and 14.1 @ 108.8 in my car. It was on street tires, and I was spinning into third gear. I ran a 13.25 @ 110.25 in 100* weather before, but they actually do prep work at that track, unlike Gateway.
Old Jul 8, 2004 | 01:48 PM
6speedZ28's Avatar
Its usually hit or miss at US41, sometimes like on a Weds night when nobody is there they don't do anything and other night I have seen them spray down alot of VHT. You never can tell with them.
Old Jul 8, 2004 | 05:57 PM
CrippleFightin's Avatar
Just finished my cam install after I had to replace my valves. My car was running like *** cuz i had bent valves. So now with new valves and a new cam, my car still has a blinking SES light and I have no idea why...crappy thing is now I have to go pay $45 for a mechanic to hook up a real scanner and tell me which cylinders are misfiring and how bad. Hopefully its not as bad as before my valve change...he tested it and 5100 was my worst misfire.
Old Jul 8, 2004 | 07:56 PM
Dark Angel's Avatar
With a big cam, the lope can cause a missfire code at idle. I had this after my TR230 cam. I got LS1 edit and followed some instructions I found on desentizing the misfire at idle and no more problems. The TPS will also cause alot of problems.
Old Jul 8, 2004 | 11:20 PM
My cam is only a TR224 .563 lift on a 112 LSA. Do you thing a moderate cam like that will cause the SES to blink? I sure hope thats whats wrong. The car just doesnt fell all that much faster. And the tires dont seem to spin as easy as usual....
Old Jul 9, 2004 | 10:40 AM
mustang5.0's Avatar
Cam Power
This is why I decided to leave the LS1 stock...
Good luck dude.
Maybe the Chevy dealer can help.
Jim
Old Jul 9, 2004 | 12:59 PM
6speedZ28's Avatar
The dealer is the last place I would take anything performance related.....or anything anything related PERIOD!
