I have $5K to put into my car
Old Dec 25, 2002 | 03:28 PM
Ed Blown Vert's Avatar
But what should I do? I want to keep the car reliable, keep drivablilty and smog legal because it is my daily driver. I want something that will give me at least 400 rwhp. But nothing I have to mess with all the time.
1. ATI Procharger
2. Head/Cam
Old Dec 25, 2002 | 03:42 PM
Drew778/94Z's Avatar
Direct port nitrous system, it's going to be hard to stay smog legal.
I'm still running my stock manifolds and cats.
Old Dec 25, 2002 | 04:35 PM
pkincy's Avatar
You can spend forever debating NA, or Huffer or Gas. So I will only refer to NA.
It will cost you close to $5K to do heads, cam, LS6 intake, LTs, custom YPipe w/cats, LS1edit (for smoggability) if you do the work yourself. But you will have a car with good driveability and smoggability (if you get someone to skip the visual on the relocated cats).
I am awaiting the heads and have everything else waiting on the Installapalooza!
Old Dec 25, 2002 | 04:51 PM
Forgot my sig, but I am already doing the N20. I want to have a bit more power on demand and not have to refill the bottle so often.
LT's are not an option because they will not pass smog.
Old Dec 25, 2002 | 05:19 PM
My84Z's Avatar
first a 12 bolt then nitrous or just a cam don't waste your money if your not gonna get a 12 bolt cause if you spend all you money and your rearend goes boom your gonna have a modded car that just sits there.
Old Dec 25, 2002 | 05:38 PM
SpecForceZ28's Avatar
first get a good rear end then if u have enough supercharge!
Old Dec 25, 2002 | 05:50 PM
PhantomTA's Avatar
Moderator
if you ONLY have 5k.. your goin to spend a lot more thtan 5k on a blower with install and tuning...
head cam headers would be the way id go
Old Dec 25, 2002 | 08:15 PM
Flat_Tire_'s Avatar
Will LT's really not pass emissions testing in CA? I would think that as long as your cat's are functioning you wouldn't have a problem. What am I misunderstanding? What about passing emissions in Idaho with LT's, anyone know?
Old Dec 25, 2002 | 08:30 PM
They should pass the sniffer, but LT's move the Cat's back. And that won't pass visual.
Old Dec 25, 2002 | 09:04 PM
Flat_Tire_'s Avatar
Gotcha. Thanks.
Old Dec 25, 2002 | 09:30 PM
PhantomTA's Avatar
Moderator
Steve at TTS sells long tubes in cali.. with cats..
appearently they pass
Old Dec 25, 2002 | 11:37 PM
pkincy's Avatar
LTs are illegal in all states. Notwithstanding that, you generally can sneak them by the visual, so you are good to go if you can sniff OK. Now in states with State Emissions Stations I would not chance it, but with contractor stations, the operator normally doesn't know or doesn't care.
PK
Old Dec 26, 2002 | 12:29 AM
Raph8erxxx's Avatar
The key here is to become friends with the guy doing the visual inspection. Buy him a pizza and a six pack or something.
Old Dec 26, 2002 | 12:34 AM
Flat_Tire_'s Avatar
Hahaha good idea Raph8erxxx. I ought to also find a new inspections guy ... last one I went to wasn't too friendly.
Old Dec 26, 2002 | 01:04 AM
stik6shift98's Avatar
nitrous with addons and install.....1k
bmr subframe conectors... torque arm....springs....rear control arms....1k
thats 2 k well spent
or get ati procharger..for 5k installed
