I am going to need a detailed list of needed parts for clutch changeout.
Old Aug 15, 2003 | 10:59 AM
99_Z_155's Avatar
All right, im changing the clutch, for sure, but i still dont know which clutch to use, the Z06 clutch, or the StarSpec stage II. which is stonger and will work the best? Either way, i need to know the rest of the parts i will need to complete the job. I am going to go ahead and change everything out, the throw out bearing and bearings, im going to change the master and slave cylinders, which brings me to my next question. if i get these at gmpartsdirect.com, do i get the regular stock camaro ones to work with either the Z06 clutch, or the aftermarket one? i am also going to get my flywheel resurfaced.
If any of you guys have done this sort of work, please fill me in on what i need to do. and it would help ALOT if i could get part numbers too, not totally necessary for those, but it would help if you got em. please give some at least slightly detailed answers.
Sorry about the long post with so many questions, but ive got a deadline to get done, and i need to know these parts.
Thanks in advance guys!!!
Old Aug 15, 2003 | 03:47 PM
thechef's Avatar
ok the spec stage 2 is much stronger than the zo6 go with the stage 2 trust me
you do know that you need to upgrade the master and slave to the 01-02 stuff these work with both set ups
the spec kit comes with the t/o bearing and pilot bearing,pressure plate,clutch disk and alignment tool and you can get the kit with or with out the new flywheel i would get then new flywheel
Old Aug 16, 2003 | 01:40 AM
99_Z_155's Avatar
Thanks man. So the 01-02 stuff is better? guess ill have to check it all out. the starspec sounds like something that is good. anyone else have anything to add?
Old Aug 17, 2003 | 11:08 AM
thechef's Avatar
the 98-00 hydralics had several problems and were updated in the 01-02 cars
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
