HyperTech Questions
Old Jul 5, 2002 | 05:56 PM
99Z28RS's Avatar
Post HyperTech Questions
When you plug in your hypertech can you reset it to the factory setting before you take it in for service?? and also does anyone know if a SLP low temp module, an shift kit, or a hypertech 160 thermostat will void warranty???
Old Jul 5, 2002 | 09:36 PM
Z_28_0117's Avatar
Post
Hypertech makes it obvious that you can and should reprogram back to stock before you take your car in for service. Look at a Hypertech manual and it says
You have the RIGHT to use high quality aftermarket parts and know that your new vehicle warranty claims will be honored. A warranty denial under such circumstances may be proper only if an aftermarket part caused the failure being claimed.
Kind of a grey area there, you can install a high quality shift kit but if it makes your tranny fail you're SOL.
2002 Z28, Navy Blue Metallic, A4, loaded exept for Performance Axle. 1 mod Flowmaster cat back...more to come!
thenewkid
Nov 27, 2014 09:41 AM
lbrowne
Nov 13, 2011 04:25 PM
SLIMJIM
Jan 7, 2003 11:06 AM
slothgrant
Aug 22, 2002 03:01 PM
Dragonballz28
Jul 28, 2002 04:45 PM
