hypertech programmer
Re: hypertech programmer
yes its only good if u have to change your rear end axle when u do a gear swap, if you are interested i have one for sale for $150 for the 00 Ls1, its stilll like new i used it only once, its all ready to go
I have the Hypertech for my car. I HAD the "power tuning" selected ON until I had my car dyno'd.....never realized how badly the motor would ping under heavy load (well, ok, I did hear it a little bit at the track, but just never realized quite how bad
). Anyway, using it for gear swap, shift point setting, and even shift firmness increase, it works great for me
Just a note though, the '00 programmer won't work for any other year.....you'd need an '02 for an '02
). Anyway, using it for gear swap, shift point setting, and even shift firmness increase, it works great for meJust a note though, the '00 programmer won't work for any other year.....you'd need an '02 for an '02
the general consensus is that they are a waste of money other than using them for gear/tire changes and transmission alterations.
the predator programmer seems to be the new programmer to use.
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
