HPS LS-1 Head package
Anyone have anyinput on The Horse Power Store's Stage 1 Street/Strip heads??? They are CHEAP but Im wondering if they are CRAP. Freind of mine is considering them. He's got the LT's and the cam...
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
ANYONE??? BEULER? BEULER? BEULER?
What specs do they post about the heads? Flow numbers AND at what lift....? Do they have a recommended cam grind for the heads? specs on the cam? What have they claimed to have dynoed with it before?...or you could give us a link
Rick
answer those questions and you will have your answer!
Rick
http://www.horsepowerstore.com/subca...200&1=205&2=-1
F'n1996Z28SS
Aug 23, 2023 11:19 PM
