How well does Hooker Cat Back flow?
Re: How well does Hooker Cat Back flow?
i got the hooker catback form my 94 a couple weeks back. i love it. i had a hooker on my old iroc, and i got another one for the lt1. i love it. sounds better than flowmaster, loudmouth, etc. i don't personally like the borla sound myself, so i can't attest to how it sounds compared to that. as far as loudness, i have edelbrock **** headers, and a half gutted cat and it's not very loud at all. hearable, but not to my pleasure. now, my iroc on the other hand had the same headers and a straight pipe in place of the cat and it was a screaming loud system when you got on it, and nicely toned when you were'nt on it. i think it's all in the cat myself. has to be... also, another factor is a cam. a friend of mine has a hotcammed 94 Z with the hooker system, and it id perfectly loud when he gets on it, and still somewhat loud when daily driving (not annoyingly loud though) i have to give the aero chamber muffler and that hooker catback 2 thumbs up!! i would put one on every f-body i ever had. oh yeah, and as far as flow, it's within a couple rwhp of about all the popular systems, including the loudmouth. (so i've heard from many reliable sources)
taken from LS1sounds.com...
2 “ Straight Pipe 283 CFM
2 ¼ “ Straight Pipe 365 CFM
2 ½ “ Straight Pipe 521 CFM
2 ¼” Typical Bent tailpipe 268 CFM
2 ½” Typical Bent Tailpipe 417 CFM
2 ¼” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ¼” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ¼” Cherry Bomb 239 CFM
2 ½” Cherry Bomb 294 CFM
2 ½” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ½” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ½” Inlet/Outlet Gibson Superflow 267 CFM
2 ½” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ½” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ¼” Inlet/Outlet Thrush CVX 260 CFM
2 ½” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
2 ½” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ¼” Inlet/Outlet 138-152 CFM
Standard OEM 2 ½” Inlet/Outlet 161-197 CFM
Also taken from LS1sounds.com...
This was performed on a 1990 Mustang 5.0 but it will still give you a good idea of how loud it will be compared to others...
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
hope this helps
hope this helps
This was also from the 1990 Mustang LX...had 370HP before adding exhaust systems...
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
I've had a Hooker catback on both of my LS1s. On a stock car, it is pretty quiet. Still sounds nice at WOT, but not obnoxiously loud. Add headers and no cats, and it wakes up really nice! Deep rumble at idle...ROAR at WOT. Less rasp than any other catback + headers + no-cats I've heard.
Highly recommended...
good luck...
good luck...
In the sound level chart, what kind of Flowmaster did they use? It can't be a 40 series if it's comparable to a Magnaflow. Anyone know how the aerochamber compares to a 40 series in terms of noise level?
Jason
Jason
I am very happy with the Hooker catback. My car made 419 rwhp through it. Volume depends on a lot of things. When I first put the Hooker on with a stock motor, it was close to stock at idle, but a little louder at WOT. Next I put a TR220 cam in. It got noticeably louder. Next FLP headers with no cats, and it was very loud. I put the FLP cats on, and it sounded much better than stock or previous setup, but was louder than the stock manifolds & cats. Later a new motor that is 11:1 compression with a 231/237 cam went it, and the cats came off. It is definately louder than it was with the TR220 and the same exhaust. Around town it is just loud. At WOT it screams, but still sounds awesome.
This is what my car sounded like with the TR220, FLP's, no cats and the Hooker.
