How much of a difference.....
Will it make if I swap in 3.73 from my 3.23 rear end?
Re: How much of a difference.....
Gas mileage and traction might decrease. Acceleration and RPMs at cruising speeds will increase a bit. I would say you would feel a noticable difference from 3.23s to 3.73s. If you're an automatic (I assume you are given the 3.23s) I would reccomend that exact gear
A converter will do much more for you.
What converter do you recommend?
There is a >500 RPM difference between 3.23's and 3.73's.
SteveC :) |
Originally Posted by Strahley
I have a 4000 in mine, it's easily streetable. Let the brake off at a stop light and the car pulls away on it's own. Just don't floor it from a dig or a slow roll without at least a good drag radial :(
if this car is your daily driver, i suggest going no higher than 3500 (vig 3200's seem to be a favorite) you are also prob gonna need mickey thompson radials (avoid nittos) or et streets or slicks to get the FULL potential out of a stall. |
| All times are GMT -5. The time now is 05:39 AM. |
