how long to run cam without tune?
Old Mar 30, 2007 | 11:50 PM
ponykiller z28's Avatar
I just purchased a TR 230/224 .575/.563 111 cam setup and it will be going in shortly. My tune won't be ready for another week or two. How long would you guys recommend running this cam with a pcm that was only tuned for minor mods?
Old Mar 31, 2007 | 07:50 AM
Kraest's Avatar
Retired
It's not going to hurt anything.
You'll just make less power and be less drivable than if it was tuned.
Old Mar 31, 2007 | 09:45 AM
Greed4Speed's Avatar
How long do you want to put up with a stumbling idle and surging?
Old Mar 31, 2007 | 01:42 PM
stumbling idle and surging won't really bother me. The main problem is coming up with the money right off the bat for a good tune. I'm just worrying about damaging something. How long should i run stock injectors with this setup?
Old Mar 31, 2007 | 02:07 PM
Kraest's Avatar
Retired
Stock 2001 injectors (28#) will be good indefinetly with a cam setup.
You need to change the injectors once you hit closer to 550 crank horsepower.
Mike
Old Mar 31, 2007 | 05:13 PM
SSpdDmon's Avatar
It's fine most of the time on one condition....
Take it easy until you get a tune. The car can help keep the AFR in line for light~moderate part throttle. But if you go flooring it, the learning become guessing and chances are your AFR will be in the 16:1~17:1 range instead of the 12.5:1~13.0:1 range it should be. Not to mention, your timing is going to be off as well.
So, you can drive it around as long as you go easy until after your tune.
Old Apr 2, 2007 | 06:59 PM
Bayer-Z28's Avatar
Mike
Don't mean to jack the thread... But on that note, is there any harm in installing larger injectors than what is needed? (waiting for future mods. Large injectors will be of use later).They just won't work as hard, right?
Old Apr 2, 2007 | 07:28 PM
If you get a tune with them in there then it should be OK. I wouldn't install them until you're ready to tune.
SSpdDmon's Avatar
Bigger injectors are fine. But, they will need to be tuned for in the PCM in order for the car to run right. I run SVO 30's to keep up with my H/C setup. The next thing on the list would be to replace the fuel pump to keep up with the injectors.
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Nov 20, 2014 06:03 PM
