How do you check......?
Old Jun 15, 2004 | 07:35 PM
CrippleFightin's Avatar
How do you check if the valves are messed up without taking the heads off?
Also, how would you check to see if a coil is bad not knowing which ones work and which dont?
Gracias!
Old Jun 15, 2004 | 07:53 PM
mullettour's Avatar
You can do a compression and leakdown test for the valves, not sure about the coils though.
Old Jun 16, 2004 | 06:34 AM
teke184's Avatar
a scanner that can monitor misfire i would think you could determine which coils are bad. and if you suspect a particular one, swap it around with another one...see if the misfire follows
BIGCOWL-IMP
Dec 27, 2012 09:09 AM
