How do you check......?
How do you check if the valves are messed up without taking the heads off?
Also, how would you check to see if a coil is bad not knowing which ones work and which dont?
Gracias!
Gracias!
a scanner that can monitor misfire i would think you could determine which coils are bad. and if you suspect a particular one, swap it around with another one...see if the misfire follows
