How difficult to install lowering springs?
Old Dec 24, 2002 | 01:13 AM
JDohn2001's Avatar
I am thinking about getting a set of lowering springs for my '98 SS. I will either get RKsport(1.5" drop) or BMR(1" drop). How hard/easy are they to install. Would you recommend doing it myself or taking it somewhere to get installed? I am pretty handy with my car. I installed my LM exhaust, air lid, CAI, MAF ends, and underdrive pulleys myself.
Old Dec 24, 2002 | 01:25 AM
stik6shift98's Avatar
sorta hard....i did that all by myself like u but i had help doin mine.....well im gettin help were in the process of doin so
Old Dec 24, 2002 | 01:34 AM
LS1rammer's Avatar
Get some help with it. It's not incredibly difficult, but not necessarily something you want to do by yourself. If you've got the experience in messing with the car and think you can handle it, go for it.
Old Dec 24, 2002 | 08:05 AM
ratio411's Avatar
If you have wrench sense it's not that bad.
The biggest thing is to take your time and double check yourself so you do it safe and correctly. Safe being a big part since the process of removing and installing the fronts is potentially life threatening if you ignore safety features on your tools.
That is another point, tools... There are several tools that you either must have, or tools that make the job much less frustrating.
For example, you must have a spring compressor, jack, jack stands, and a T-50 mounted in a socket along with all your standard hand tools.
Things that make the job shorter and less frustrating are things like an impact wrench (air or electric) and pickle fork.
I have tips and tricks for cutting stock springs on my website, not all of it applies if you have aftermarket springs, and I don't go into every detail of the process, but some of it might be helpful if you want to check it out.
Good luck
Dave
Noenav
Mar 1, 2019 07:38 AM
chuyz28
Feb 19, 2015 12:50 AM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
