How to change DRL?
How to change DRL?
One of my DRL's is burnt out, and that was what was causing my turn signal to not blink. How do i take the DRL cover off to get to the bulb? I dont want to crack it or anything. ALSO what bulbs do they use? Thanks.
You don't take the cover off. If you lie down and look under the car by that light, you will see a plastic flap that is held closed by a couple of bolts. Take these out, and open the flap. You will then be able to reach up and take the bulb out from behind. All you have to do is twist it. I don't remember the part number for the bulb off the top of my head, but you can get it at any parts store for a couple of bucks.
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
