How big is to big?(exhaust)
Old Apr 8, 2005 | 08:06 AM
z28man86's Avatar
i was just wondering how big of a pipe i should use. I was thinking of using 3 inch piping into turndowns. Is that to big should i go with 2.5 inches? I also am wanting to run an H pipe.
Old Apr 8, 2005 | 08:23 AM
teke184's Avatar
Re: How big is to big?(exhaust)
3" piping is fine, you may lose a bit of low end torque but will really gain on the top end.
i personally would try something like 2.75" pipe, get a little more clearance
and i think an X pipe yields better sound and power than the Hpipe
Old Apr 8, 2005 | 09:39 AM
00ls1's Avatar
i have 3" from the headers back.. no clearance problems here
Old Apr 8, 2005 | 11:19 AM
z28man86's Avatar
yeah i know X pipes are better but H pipes are cheaper(short on funds right now). if i lower my car will i have clearance problems if i go with 3 inch?
Old Apr 8, 2005 | 11:32 AM
Greed4Speed's Avatar
I have clearance probs w/ 2.5" Y on my car and its only 1.4" lower.
Old Apr 8, 2005 | 02:05 PM
z28man86's Avatar
so then what is a good setup to go with? I went to a few shops around and they were concerned with the clearance. I want my exhaust to be loud,so i was thinking of glasspack turndown before the axle. Would that be loud?
Old Apr 8, 2005 | 02:12 PM
sir dyno's Avatar
I've heard 4inch exhaust pipes would be too much of a pipe, becuse you still need some back pressure or you could end up loseing horsepower.
If your worried about clearence issues, you can always get the bmr panhard rod relocation kit. It allows you to use a bigger ehaust pipe over the axle.
Some people get an elictric cut-out, so when they want loud or stock its a close, open deal.
Old Apr 8, 2005 | 09:52 PM
CrabhartZ28's Avatar
Seeing as you have clearence issues, i don't think you would loose anything important by going to 2.5". Then again, i'm not sure what your clearence is like right now. How much did you lower it?
Glasspacks are overrated and outdated technlology in my opinion. They would be loud but if you go with a bullet muffler, no muffler, no cat, or like sir dyno said, a cut-out, you won't have to worry about sound.
Even the stock sound is very sexy again, IMO.
Old Apr 8, 2005 | 10:21 PM
z28man86's Avatar
[QUOTE=CrabhartZ28]Seeing as you have clearence issues, i don't think you would loose anything important by going to 2.5". Then again, i'm not sure what your clearence is like right now. How much did you lower it?
i dont have it lowered yet but i was going to get the eibach pro springs.
Old Apr 8, 2005 | 10:29 PM
oh i see. I wouldn't do that if you're going to get 3" pipes.
Old Apr 9, 2005 | 06:34 PM
Glasspacks = crap
I have yet to see any packs that didn't drop down .25" in diameter for the tubing inside the muffler. Either get twisters, bullets, or some chambered sticks that don't neck down or go with something like the Borla XR1.
I have a 4" mufflex. Needing backpressure is a myth. Larger pipes are great for HP but drop torque due to lost velocity.
Eibiotch pro's aren't that low, but I've read too many posts about them settling lower in the rear and letting the car hit the bumpstops.
Old Apr 10, 2005 | 01:31 AM
Fast_Toys's Avatar
If you decide that you want a Mufflex 3.5 or 4" system, we have a GP running right now. Email us at sales@fasttoys.net with the year and model of your car for pricing.
Thanks!
Louey
Pacific
Apr 7, 2015 02:10 AM
jasonduaine
Apr 1, 2015 08:09 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
MadMav
Feb 6, 2015 11:02 PM
