How bad is it to bounce off the rev limiter in an A4?
Old Aug 26, 2003 | 12:19 PM
MeanWS6's Avatar
I have been having some probs with my trans recently, so I hit the rev limiter a few times at WOT. What damage can result from this? How will I know if I damaged something?
Old Aug 26, 2003 | 12:27 PM
nikkev's Avatar
Shouldn't hurt anything.The rev limiter is a computer program that cuts fuel at a certain RPM to keep you from mechanically over-revving the motor.When you mechanically over-rev the motor (like shifting into the wrong gear with a M6) then you usually bend the pushrods and that's about it.Good luck.
Kevin
Old Aug 26, 2003 | 08:29 PM
Y2kPewterSS's Avatar
I'm not sure how you can hit the rev-limiter in an A4, so I can't say that you didn't/couldn't cause damage. I'll tell you in my M6 that the rev limiter kicks in before you know it, and more importantly before the tach registers 6200 rpm. The tach seems slow when it is winding up and I have to shift before red-line or I will hit the limiter.
Brian
Old Aug 26, 2003 | 08:50 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Brian
when you trans is slipping it can hit that rev limitter damn hard.
its fine for the motor, your trans hates you.
Old Aug 26, 2003 | 08:52 PM
SSpdDmon's Avatar
I was always told bouncing off the rev limiter causes excess strain on your valvetrain and doing it often can cause some problems in the long term. I forget the specifics of why this is true, but I stand by it. I hate bouncing off the rev limiter.
Old Aug 26, 2003 | 09:07 PM
treyZ28's Avatar
its by no means a good thing-
but kissing it once or twice isn't all that bad
Old Aug 27, 2003 | 01:50 AM
AL SS590 M6's Avatar
Moderator
LS1 motor with the stock rev limiter. Your pretty safe. I've hit mine a lot until I got a programmer to touch up the 2-3 shift.
HarleyZ28
Oct 5, 2015 06:23 AM
detroit1994z28
May 14, 2015 12:09 AM
cristian1311
Apr 22, 2015 10:20 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
