Higher temps with Loudmouth?
Old Aug 11, 2003 | 04:16 PM
ls1camarogal's Avatar
I had the SLP LM & Y-pipe installed 3 1/2 weeks ago and I've been noticing that my engine is running 5-10* hotter on the highway than it was before (when I only had a Flowmaster muffler), and as soon as I get off the highway, it immediately jumps to 210*. Has anyone else noticed this? I know it's probably a stupid thing, but I'm just curious if it's a common thing or if I've got a problem somewhere.
Old Aug 11, 2003 | 04:31 PM
JustAnotherT/A's Avatar
im probably wrong but you might have a leak and its re suckin in all the hot fumes from the y-pipe area. I had loudmouth before and it never made my car hotter.
Old Aug 11, 2003 | 05:45 PM
lastZ's Avatar
i have the slp LM...never noticed that problem, sorry!
Old Aug 12, 2003 | 05:18 AM
edg1957's Avatar
My temp never changed with the LM. I have read in the forums that the temp gauge is horribly inaccurate though. You might want to investigate your cooling system...
Ed
Old Aug 12, 2003 | 09:10 AM
Lasombra52's Avatar
on 98 LS1 F-bods the gauge is accurate. In 99 (I believe) they went to the inaccurate gauge.
I have the Loudmouth, and I'm not running that hot in the Florida heat. I'm normally around 180, 185
Old Aug 12, 2003 | 10:50 AM
SheDevlLS1's Avatar
I never had a temp change either...even when I installed LT's.
Old Aug 13, 2003 | 04:28 PM
I figured it wasn't due to the LM, but maybe more of an installer error. As soon as I get the clutch replaced I guess I'll be back to the muffler shop.
93 RedBird
Nov 15, 2015 08:24 AM
95chwagon
Oct 16, 2015 12:24 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
