HELP!!! Weird tapping noise.
I had a slight tapping in my car that was loudest around 1500-2000 rpms. The engine wouldn't tap until it got warmed up. I opened the hood and noticed it was only on the passenger side of the engine. I had some friends look at it and was told its probably a rocker arm. I pulled the valve covers and rocker arms. One of the push rods was bent just a bit. I got scorpion roller rockers with a 1.7 ratio. I also got the manley 7.4 long and 5/16th push rods. I installed everything, torqued it and reassembled all the parts. I started it and ran it for about five minutes. Nothing at all. I got in my car and left for my house about a mile away. Halfway there the notorious tap again. I opened the hood and listened to it. Now it seems to be a bit louder and just the same thing. 1500-2000 rpms is when it is the loudest. At idle it does not tap at all. When the rpms hit around 1250 the tap is there and fairly quiet. Over 2000 rpms i think the engine noise is drowning the tap out. Any ideas or thoughts of what it could be? I need to keep the price down because I am planning a wedding for Sep. 12. Please help me out!
So pull the heads and check for a bent valve? Do you have any other sudjestions as to what it could be? I was told to get some stuff called sea foam and put it in my intake and see if that fixes it. I was told that maybe it is a carbon build up on my valves and its not allowing it to close all the way. That in turn is causing my rocker arms to tap on the push rods? Possible? Worth the try?
I have no clue what bent the push rod. The last time I even reved it above 3000 was on the highway when I race a twin turbo hoped up diesel truck that thought he had something. I was on a long road trip from Jersey back to Ft. Campbell. That was about a months ago. About a week after I was back my oil change was due. That same week it started tapping out of the blue. I hoped that when I changed my oil that it would go away. Not so much. It did seem to get quieter with the oil change but it was still there. This is a dd car so I try not to race it or beat the ***** off of it as it is my only car! I haven't changed any of the internals on the engine up until this point with the rockers and rods.
Is there any way you can get a sound clip? I don't even know why you have aftermarket rockers on a totally stock engine. Very high revs (miss shift) normally causes bent pushrods, do you have an M6 or A4? Could be normal valvetrain chatter, really can't tell without a sound clip.
Im going to be completely honest with you. I have no clue how to do a compression test. I will have to take it to the shop on post and ask the mechanics there to help me. Also I was wondering if it could be a lifter too? I have heard from some coworkers that it may be that. I will try to record a sound clip. The only problem is that I will have to do it off of my phone and I am not sure how good of a quality it will be. I will try to do that tonight.
If I were you sell the Scorpion rockers to get some $$$ back, no need for those. Stock rockers are the best out there for most applications, with upgraded bearings there is hardly any need for aftermarket. Too much weight over the valve.
I'd do a compression test, probably a bent valve.
here is the link to the video. i am going to get a compression tester tomorrow and throw it on there tomorrow evening to see what happens.
http://s926.photobucket.com/albums/a...90806-1713.flv
That sounds really bad. It's hard to tell, but that sounds like something in the middle of the motor. Lifter? My bent rod sounded like that as well, but it's hard to tell with the camera phone.
Pop the valvecovers and see what's up again.
