Help Voltage gauge going down
Old Sep 23, 2003 | 11:28 AM
01_camaro_DTX's Avatar
I upgraded my sparkplugs to bosh platinum 4's and my cables to msd's 8.5mm. Now suddenly after driving the car for a while when I let go of the gas pedal at about 40 mph my voltage gauge drops to the bottom and my lights dim and the car feels like its going to stall. Also when the car is parked and idle it feels like its going to turn off but it does not. Does any one have an idea of what could this be. Also if I do not use the car for more than 24 hrs it will not start after wards or start very weak. I changed the battery but it still doing the same thing. PLEASE HELP!!!!!!!
Old Sep 23, 2003 | 01:04 PM
NEWBIE T/A's Avatar
Lightbulb Check for simple stuff.
For example -
any possibility that you disconnected one of the wires running to the alternator ?
Auto Zone offers free on site testing - that's another route to take.
My guess from what you have described is that the alternator is going bye bye.
Have it checked before you spend more $'s , though.
Good Luck !
Britt
Old Sep 23, 2003 | 01:36 PM
If I do replace the alternator, do you have any suggestions on a good one to get for my f body.
Old Sep 23, 2003 | 02:05 PM
NEWBIE T/A's Avatar
Lightbulb Never done a 4th gen F alternator, but ...
I have had very good luck w/ the A/C Delco line of rebuilds.
O'Reilly's here in H-town carries them - not sure where you are (can't see the sig while replying) so no clue as to who is in your neck of the woods.
Don't waste your time or money on anything other than a lifetime warranty unit, though.
Britt
Old Sep 26, 2003 | 11:50 AM
NEWBIE T/A's Avatar
Exclamation Found one other interesting tidbit.
http://www.zmydust.com/alternator.htm
May be of interest.
Britt
Old Sep 26, 2003 | 05:01 PM
rncotton's Avatar
Yup ... sounds like an alternator, especially since changing the battery didn't help.
Either you bumped something loose, moved a wire by mistake, or just by coincidence your alternator decided to crap out at the same time you did your wires and plugs.
Formula Steve
Sep 19, 2023 08:31 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
