HELP! Please....car is dead!
Old Nov 23, 2002 | 04:37 PM
Pentatonic's Avatar
Unhappy HELP! Please....car is dead!
I was working around the engine compartment in my car. I did not disconnect the negative terminal of the battery. To make a long story short, I dropped the wrench, and it made contact with the positive terminal of the battery, and a metal (grounded) part of the car. Sparks flew, and the car alarm went off. I got my keys and hit the horn button to disable the alarm. I then hit the unlock button and got in the car. The car does not start, does not click, the lights do not go on. Everything is dead.
I checked the battery and it is fully charged at 12.68 volts. How expensive is my mistake? Did I fry the ECM? Maybe it is something simple like the theft system?
Please Help!
Thanks for reading this.
Old Nov 23, 2002 | 05:05 PM
SpecForceZ28's Avatar
A similar case happend to me about 3 weeks ago, i too did not disconnect the negative terminal, but that was because i didnt have anything that fit the lug nut. Well I tried to use something else, but sparks flew, then i dropped it, then more sparks. Check the fuses, make sure they are good, it could be just as simple as a bad fuse, but I could be wrong
Old Nov 23, 2002 | 06:36 PM
LS1CAMARO's Avatar
Check fuses and relays. Look in manual and chaeck all fuses.
Old Nov 23, 2002 | 06:42 PM
MRZ28's Avatar
Fuse
Your main fuse is blown.
Old Nov 24, 2002 | 11:58 AM
Pentatonic's Avatar
OK, the problem is fixed Thanks to all who replied.
It turns out I got lucky and did not blow a fuse. I went out this morning, and engaged the car's alarm system, and then disengaged it. I got in the car and started it up. The car started, stumbled, and then the engine died. The security light was on.
A minute later, I started the car again, it started up and ran just fine. I drove it around, and it drove fine. So I guess the problem was with my security system.
Old Nov 24, 2002 | 05:09 PM
MRZ28's Avatar
Cool
Im glad to here it was nothing major. I couldn't lve with my self if somthing happend to her
Old Nov 24, 2002 | 07:02 PM
JurisAg02's Avatar
Re: Cool
wow, some peoples devotion to a car....amazing LOL
Old Nov 25, 2002 | 01:08 PM
PWTRTXSS's Avatar
did you check to make sure that your security system still works?
I would make sure that it still makes noise when it goes off and stuff like that.
'96Z28
Jun 30, 2015 05:46 PM
MadMav
Jun 15, 2015 09:51 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
stangspank
Aug 13, 2002 01:45 PM
