Help please!!!
Old Apr 10, 2009 | 08:01 AM
Stoney0422's Avatar
Exclamation Help please!!!
if you saw my prior post i was looking at a 98 camaro z28, well i bought it. Second day driving i went over a speed bump, they are terrible here, and scratched the bottom going slow it was just to tall. Well shortly after a bracket of some sort came out, Not sure if its related but i think it is. The bracket does no have a part number though. Only markins say V8 and next to that it has a p inside on a c. this bracket has a piece that looks like it lides in or on another piece and then mounts to something but not sure what, as of right now i have no way to post pics. I have some in my cell phone though so i can send them to anyone willing to look. thanks in advance.
Old Apr 10, 2009 | 09:05 AM
Rice Killer87's Avatar
Sounds like the torque arm mount to me...it bolts to the back/side of the transmission.
Does it make a clunk sound now when you hit the gas?
Jack the car up (not on the oil pan) and look for the long arm going from the side of the rear axle to the back of the transmission. If its not that, just look for something broken.
Old Apr 10, 2009 | 10:07 AM
johnny6's Avatar
Send me the pics from your phone, there's alot of "brackets" underneath the car, it's almost impossible to tell with the description you gave.
Old Apr 10, 2009 | 10:16 AM
Stoney0422's Avatar
Pictures sent and I havent really driven since it fell not sure if i should and when i did i drove real easy but no i dont think there was a clunking and i have looked for whats missing and cant figure it out.
Old Apr 10, 2009 | 10:21 AM
Stoney0422's Avatar
actually while i am asking questions about it, how difficult is it to replace the high pressure power steering hose on this thing?
Old Apr 10, 2009 | 10:29 AM
johnny6's Avatar
Ok just got the pictures, that bracket keeps your Y pipe from moving/vibrating. If you crawl under the car on the passanger side, look at your Y pipe and it will have a flat metal bracket, that piece you have has a rubber mount with a slot in the middle for the piece of the Y pipe to slide into. When you slide it back on just look for the correct holes to screw the bracket back into place.
Old Apr 10, 2009 | 10:33 AM
Stoney0422's Avatar
so i will probably need to buy the rubber mount? and thank you i will look when i get a minute from work
Old Apr 10, 2009 | 10:36 AM
Stoney0422's Avatar
oh and if i dont get it fixed right away its not to big of a worry right
Old Apr 10, 2009 | 10:46 AM
johnny6's Avatar
Look at the mount and see if it's ripped, the bracket could of just gotten loose and slid out of the Y pipe. You'll be ok driving around with it, actually to be honest i don't even know if mine is on there or not.
Old Apr 10, 2009 | 10:53 AM
Stoney0422's Avatar
awesome thanks for the great info!!!!!
