HELP overheat and now Knocking!
Old Jul 8, 2005 | 11:30 AM
poxz's Avatar
Ok I've been meaning to get my belts changed for a month now because they were squeeling on cold starts for at leat 10 min. Then The other night I drove about 15 Miles to my work. When I got back home I noticed some steam coming out of the hood So I pop the hood... Water and I think Antifreeze everywhere. So I check fluids and Oil is low and no coolant left. (cause its all over the engine) So I put water in for radiator and Put a Q of Mobile One in. Start it up and Squeeling is still there but now There is a knocking that sounds like its comming from right where the TB meets the Intake Manifold.... It does not sound nice.........
Any thoughts??????What do you think needs to be replaced?????
Old Jul 8, 2005 | 11:40 AM
shouldaboughtthez's Avatar
Re: HELP overheat and now Knocking!
you said coolant is everywhere under hood. Can you see any place it might have come out at, i.e. busted hoses? Did you put the cap on the radiator good.
As far as the knocking sound, I hope you didn't overheat it enough to mess something up pretty bad.
Old Jul 8, 2005 | 11:46 AM
poxz's Avatar
Well when I stopped it was leaking all over the ground. but after it sat (off) for a couple of minutes I added water in the raditr. and then the Q of oil and then started it and no more leaking anywhere but thats when the knocking started. And it over heated from a 10 min drive.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
