Help Needed w/ Clutch/Slave/Master/Flywheel
Old Jul 9, 2002 | 10:07 PM
BGBsSS1's Avatar
Question Help Needed w/ Clutch/Slave/Master/Flywheel
My clutch slave cylinder went out yesterday and fouled the clutch up as well. The dealership quoted me $1100 for replacement parts alone. So, I am upgrading while I am having them do work.
While I have them down working in this area, is there something else that I should go ahead and replace or upgrade?
Suggestions on clutch kits, flywheels, and slave/master cylinders would be helpful as well.
Right now, I'm thinking about going with a Cartek Clutch, Mcleod master/slave cylinders, and I have no clue about the flywheel.
Thanks.
'98 SS, Dk. Met. Blue, M6, Lou's Short Stick, SLP Short Throw, Whisper Lid, K&N, SLP Smooth Bellows, Granatelli MAFS, SLP 2nd Source Ram Air, Borla Quad Exhaust, !CAGS, BMR Struttower Brace, SLP Subframe Connex, BMR Panhard
Old Jul 10, 2002 | 04:41 PM
TA2001's Avatar
Post
here is some info on cartek install
http://ls1info.com/article.php?sid=242
replace master,slave,flywheel,throwout,
clutch..
you may want to go with the Z06 clutch.
It seems to do very well.. and cost
efficient.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
