Help my build my car..
Old Feb 17, 2007 | 10:33 PM
95TA8280's Avatar
Hey guys,
I am completely redoing my 01 M6 TA. I was going to get another car, but I think I want to redo this one. I need emissions, so that is a factor. Basically, I want a new cam and heads, full exhaust and ot make it Ram Air.
Here is my "wish list" at Thunder Racing. What else do I need to complete this?
I plan on switching out the motor/tranny next year to something bigger with a supercharger, but that's down the road.
Wish list:
http://www.thunderracing.com/wishlis...view&wlid=8072
Comments?
Matt
Old Feb 18, 2007 | 09:12 AM
AL SS590 M6's Avatar
Moderator
Where to start. The hood and headers are a good start. If this is only an interim package there are way way cheaper packages out there. Now if this was to be a build for keeps then maybe.
Check out the heads/cam packages at some of the other vendors.
The WS6 hood and the SLP air induction do NOT equal a ram air setup.
Old Feb 18, 2007 | 09:42 AM
95TA8280's Avatar
Al,
What type of set up do you recommend for cheaper?
Matt
Old Feb 18, 2007 | 01:08 PM
Moderator
Originally Posted by 95TA8280
Al,
Matt
Something like this
http://www.texas-speed.com/shop/item...d=203&catid=47
would be a good starting point.
Old Feb 18, 2007 | 02:16 PM
95TA8280's Avatar
What about the exhaust set up that I have in my TR wish list? How's that? Also, in the set up you suggested, how big of a cam can I go to still be emissions legal?
Old Feb 18, 2007 | 10:58 PM
Kraest's Avatar
Retired
Cam sucks (too small), heads suck (overpriced pieces of crap. You can get Dart 225s for $1000 less and make more power), rockers are pointless, etc, etc.
You need to do more research here and/or follow what Al, Teke, and I have been saying for years.
Start over.
Old Feb 18, 2007 | 10:59 PM
Moderator
To stay totally emmisions legal you can NOT move the position of the cats so shorty headers would be your only option. Now if your area isn't too strict then you might be able to get by with the Mac mids.
As far as cams go it is again up to what the testing regimin is in your area. If they just do a sloppy visual and plug into the comp to look for codes you could get away with alot. With sniffer tests it will take a good tune to get anything more than a very mid cam by them.
Old Feb 19, 2007 | 10:50 AM
95TA8280's Avatar
In my area I know I can (although it's illegal) move the position of my cats...they just plug it into the computer and do a half *** visual to see if I pass. I just don't want to fail emissions.
Old Feb 19, 2007 | 12:47 PM
teke184's Avatar
you can find better cams with similar duration than that...but with better lift for the same price.
no need to buy a low lift cam and then a $600 rocker upgrade when you can buy the cam with the lift built in.
try Futral or TSP
then some budget heads like the Dart 205s or 225s...or even some of the budget LS6 heads.
oh by the way...read the last sentance in the description of the cam you chose..."not reccomended for use with 1.8 ratio rockers"
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
reww86
Aug 29, 2015 06:04 PM
