Help me find: Scraping/Grinding Noise
Old Mar 13, 2008 | 03:20 PM
ZZtop's Avatar
I have an odd rotational "scraping" or "grinding" noise coming from the front of the engine. This noise can be heard with the hood closed and "whines down" to a stop when you turn the engine off. The odd part is that so far it only makes the noise when hot, say after driving at operating temperature for a while and then coming to rest at idle in a parking lot.
My initial thoughts are water pump or an idler pulley. I do own a stethoscope and will poke around but wanted to get some other ideas of things to check first.
The car is a 2002 Z28 with 44,xxx miles on it and it started making this noise out of the blue.
Thanks for the help.
Old Mar 13, 2008 | 04:05 PM
Zitty'sZ's Avatar
Remove the two drive belts and hand spin all the accessories including the idler pulley and you should find the problem . If the idler pulley is the problem , there is a sticky at the top of the forum that tells you how to service the bearings yourself and save some money . Good luck !
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
