Help...Extra hole in my SLP Lid!
Old Aug 5, 2002 | 06:10 PM
Jay-mak's Avatar
Post Help...Extra hole in my SLP Lid!
I just got an SLP lid and there is an extra hole in the lid that I don't know what is there for. Lets say your facing the front of the car then the hole is on the driver's side. Also, there is a metal pipe/tube that came as well. Can anyone help.
P.S. I hooked up everything my OEM lid had hooked up to it.
Thanks.
1998 Z28. Artic White.
  • SS hood
  • Sport Appearance pkg.
  • Ported, Polished MAFH
  • Free ram air Mod.
  • Flowmaster Exhaust
  • Custom Stainless tips
  • T-tops
  • SLP Lid
  • KN air filter
Old Aug 5, 2002 | 06:14 PM
WipeOutXXL's Avatar
Post
There is another hose that was in the thing right after the stock lid. its for "Emissions" and there should be another rubber hose that plugs into there. That's the only thing I can think of.
Old Aug 5, 2002 | 07:22 PM
nikkev's Avatar
Post
The 2000 and up cars have the extra hose.Our '98s don't.Just block that hole off.My SLP came with a little rubber seal that was stuck in there.
Kevin
maddboost's Avatar
Post
Make sure the lid you ordered is for a 98 fbody and not a 2001 and on because im pretty sure that the newer fbodies have some electronic plug in there.
98 Red Z28 A4 bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
Old Aug 5, 2002 | 10:43 PM
redz_02's Avatar
Post
Yup 2001, and 2002 need that hose. It is to measure the temp in the lid, or air temperature. I believe in the 98's to 2000's its in the intake or by the throttle body. So SLP sent you the wrong one. It will fit though, just block it off.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Old Aug 6, 2002 | 11:38 AM
rncotton's Avatar
Post
It's either the air-temp sensor hole, or the place where you hook the hose to the AIR pump (which is what the pipe is for)
Is it a small hole about 1/2 " in diameter, or is it a larger hole about 1" in diameter?
Is it on the lid itself, above the filter, or is it towars the back, along the neck?
That will tell us which hole you're referring to.
Air temp module in the small one (you car may not have one there, but you could relocate it there for slightly better performance)
Large hole is for the AIR Pump tube, runs down to the driver's side wheel well.
2001 TransAm WS6, M6 3.42
HPP, TBB, 160* t-stat, MTI Lid, Holley PowerShot, Flowmaster 80, Port/Polish MAF
Pics of the T/A
2001 Z28
-- R.I.P. - 06/25/02
Old Aug 6, 2002 | 05:56 PM
Jay-mak's Avatar
Post
Thanks guys, I believe I have purchased a lid for a 01-02 camaro inside of my 98. I'll just block the hole off.
Any ideas where to get a rubber plug?
  • SS hood
  • Free ram air Mod.
  • T-tops
  • SLP Lid
  • KN air filter
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
drt
Sep 27, 2015 04:39 PM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
