Help: Coolant leak/problem :(
Old Oct 28, 2003 | 08:38 AM
lucky_topher's Avatar
When I am driving, once my engine warms up, i start to smell coolant... i can smell it from in the car... there are no visible leaks under the car, there are no visible leaks in the passenger floorboard (where i was told it would leak if it were the heatercore)... i stop, pull over, pop the hood, and look & sniff and cannot find the leak... i do not SEE anything at all.... i smell it without turning on the heat/air... even w/ the windows up... could it be a hole in my radiator? i've replaced the water pump & gaskets already... and i've flushed and refilled the coolant...
HELP!
Old Oct 28, 2003 | 09:37 AM
NEWBIE T/A's Avatar
Lightbulb If you smell it in the car, it could still be the heater core.
Try Auto Zone and see if they will rent or let you borrow a pressure tester.
That should help you pinpoint the leak.
Also look for tell-tale signs, such as weepage marks (white streaks) on the neck of the radiator.
You did not include a sig that shows your car year , but I remember seeing a bulletin talking about polishing the radiator neck to prevent weepage.
See here for '99's:
http://web.archive.org/web/200111080...06-02-001.html
Good Luck !
Britt
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
