Heads/Cam swap question
Old Jun 20, 2004 | 04:55 PM
USHotRod's Avatar
When doing a heads/cam swap, what other considerations need to be made? Is this just something that you can do without adjusting anything or having something else in conjunction or what? Thanks.
Old Jun 20, 2004 | 05:26 PM
BirchMan98z's Avatar
you may want to consider pumping up your fuel injectors, idle speed, rev. limit. Be sure to check your oil pump. IN fact, as long as you're down there, since you have to remove the oil pump anyway, consider replacing it with the heavy duty SLP pump, or the ls-6 oil pump. $140 you can't really go wrong with this simple mod. You'll most likely want a tune after a heads/cam swap. Your Air/fuel ratio will go haywire.
Old Jun 20, 2004 | 06:31 PM
CrippleFightin's Avatar
Some LTs to free up alot of extra horsepower from those heads and that cam!
Old Jun 20, 2004 | 06:51 PM
USHotRod's Avatar
Actually, thats getting bought right along with them. Now to pick which...
Old Jun 20, 2004 | 07:13 PM
I have Hookers and love em. Jet Hots are pretty cheap and are great headers, and I hear good things about Flowtechs as well.
Old Jun 20, 2004 | 07:16 PM
USHotRod's Avatar
Heard about the FLowtechs too huh? Definately leaning towards them.
Old Jun 20, 2004 | 07:57 PM
teke184's Avatar
i love my flowtechs....the whole header project cost me under $600 which included all gaskets, pipes and extensions
Old Jun 20, 2004 | 07:59 PM
USHotRod's Avatar
Explain please...
Old Jun 21, 2004 | 12:20 AM
mullettour's Avatar
Explain please...
I know you were asking teke but I'll answer for him. Pipes=y pipe gasket=collector gaskets (and I believe he did egr and air block off to so probably those as well) extensions=02 sensor plug extension. If that isn't right teke can correct me.
Old Jun 21, 2004 | 01:08 AM
AL SS590 M6's Avatar
Moderator
Don't forget to upgrade your valve train. Your new heads will have heavier springs so you'll need better pushrods and timing chain at the very minimum. If it's a high mileage car new lifters and rockers wouldn't be a bad idea.
Old Jun 21, 2004 | 03:29 PM
USHotRod's Avatar
Actually I was aking how he came in under $600 for the whole deal. But thanks anyway.
Old Jun 21, 2004 | 07:52 PM
Dr.Mudge's Avatar
Headers/injectors should be a given to me anyway, lid sure - programming a must. Of course some people are happy with a flaky powerband and less than stellar gas mileage.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
F(ast)-body
Feb 26, 2003 09:05 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
