Heads And Cam?
Old Feb 25, 2006 | 01:19 PM
joshs97ss's Avatar
Heads And Cam?
Please advise!
I am thinking about putting MTI's Stage 2e ported heads, x1 cam 230/227 .592/.571 112, Fast 90mm intake, fast 90mm tb, Mti underdrive pulley, qtp or kooks lt headers with bassani true dual exhaust. Heads are going to be fully preped with vavle the hole 9yrds! Questions 1.Am i going to need to mod the fuel system i.e injectors, maf, and fuel pump?If so What to what? 2. how aggressive is this set up really going to be? 3. What kind of horsepower will this make?? Thanks guys Really Look forward to your responses Sincerely josh B P.s It going on a 02 ss, m6 with 6800miles on it
Old Feb 25, 2006 | 02:09 PM
teke184's Avatar
Re: Heads And Cam?
with a good tune, and assuming the heads flow well, you should be in the 430-440 rwhp.
if the tune is good, it shouldn't be to aggressive. there are some much nastier setups out there.
injectors will need to be upgraded. look for the SVO 30# injectors. maf is fine stock and the fuel pump is fine.
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
