headers
Old Jun 9, 2005 | 10:04 PM
ls1650's Avatar
headers
hey guys its been a few weeks since i got my new lt pacesetters installed n now i see the SES light turns on. i have the o2 sims n extentions installed too so wat do u think the cause can be? also it smells kinda bad under the hood i mean it suppose to smell bad when u first get it installed n start it up but it has been like that for 2 weeks. also there is some kinda noise coming under the car which i think is the y-pipe. when ever i step on the gas i hear a weird noise. does anyone know what this could be?
Old Jun 9, 2005 | 10:13 PM
Schmidt519's Avatar
Re: headers
From what I heard the 02 sims sometimes don't always kill the SES, an LS1 edit is what you should have done. Thats why I waited until I got my car tuned to worry about the headers causing the SES. The smell is very normal, its only the top coating on the headers getting burnt. And I also had a noticeable rumble noise on start up and WOT right under the driver seat right after the install, it went away after a few weeks, really not sure what was causing it initially, but it went away fairly soon.
Old Jun 11, 2005 | 12:52 PM
RS Dragster's Avatar
Re: headers
Did you take off the EGR or AIR system as well? If so, that could be throwing a code.
Old Jun 11, 2005 | 08:25 PM
ls1650's Avatar
Re: headers
ok guys i found the code it is p0135 refers to heat curcuit malfuntion bank 1 sensor 1. what does that mean? how do i fix this problem?
Old Jun 19, 2005 | 09:59 PM
slayer6x6's Avatar
Re: headers
Thats a code for your o2 sensor heater. I would swap your pre cat o2 sensors and see if the code changes to a bank 2 sensor 1. If the code changes replace the o2 sensor.
Old Jun 20, 2005 | 11:32 AM
teke184's Avatar
Re: headers
make sure the wires are zip-tied out of the way so that you don't (or havn't) burned one of the sensor wires.
could explain the delayed SES
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
