Header install ?'s / help
Old Apr 28, 2005 | 10:15 PM
SScamaro463's Avatar
I just put my Jet hot LT's on. Now i am trying to put my TSP ORY on also and the drive side seems to hit he bottom o fthe car. Has anyone one here had this problem ? if so how did you fix it and get the ory to work. i meen when i try to put the ory on the collector
Derek
Old Apr 29, 2005 | 06:51 AM
teke184's Avatar
Re: Header install ?'s / help
take a torch and heat up the section that hits...bang in some indentations for clearance.
by any chance did you install poly motor mounts? because they will eliminate most engine movement and keep the exhaust from hitting the frame when the engine torques up.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
