Header install..
Header install..
I am fixin to install my new Pacesetter headers and Y-pipe.
Is there an install guide somewhere that also lists the tools ill need..or just one of the above.. I already searched with no luck..thanks in advance
02 Z28 A4
02 Z28 A4
http://drs.yahoo.com/S=2766679/K=ls1...icles/mac.html
Those are MAC mid-lengths,but the install process should be the same.Good luck...
Kevin
Kevin
Originally posted by blackztpi
undo the motor mounts and jack the motor up for clearance. from there, it's all luck for how long it takes you
I put my Pacesetters on a few months ago.
1. Have a lift, it will make your job so much easier
2. if you have access to a torch, just torch the stock manifold/ypipe connecting bolts off
3. 10mm 1/4 socket and rachet are your best friends, especially the last manifold bolt on the passenger side.
Passenger side header slides right up in..no problems
Driver side header, I unhooked my steering column, moved it out of the way and put the header in...hooked the steering column back up and away I went. 5-7 minute job.
If you are planning on doing this job on jack/jackstands...good luck...I did one set of headers for my friend that way and it totally sucked.
If you're in/near Lancaster PA and need help, PM me...hope all is well and good luck with your install!
