Gummy Orange coolant-- head gasket?? HELP!?!?
Old Apr 1, 2005 | 08:34 PM
tombodad's Avatar
Hey guys
Coolant lights been going, it was fine, but now i look in the coolant reservoir and its all brownish orange and gooey. Not good at all. Doesnt really overheat too bad at all though. Is this a blown head gasket? intake manifold gasket? somebody? anybody?
Old Apr 1, 2005 | 08:38 PM
Greed4Speed's Avatar
Re: Gummy Orange coolant-- head gasket?? HELP!?!?
Originally Posted by tombodad
Hey guys
Its called Dexcool. It does that.
Old Apr 2, 2005 | 01:44 AM
tombodad's Avatar
so this orange silly putty in my coolant reservoir is normal and wont hurt anything? i cant believe that...
Old Apr 2, 2005 | 08:59 PM
Believe it or not, makes no diff to me.
Old Apr 2, 2005 | 10:13 PM
95_LT1_6SPD's Avatar
I wouldnt say it wont hurt anything. Id change it out, but it is a characterstic of dexcool.
Old Apr 3, 2005 | 06:55 AM
DaddySS's Avatar
Blown headgasket generally makes the coolant overflow badly and the coolant gets a tan foamy creamy salad dressing consistency. Dexcool gets contaminated and starts to develop the sludge. If it's not overflowing, it probably just needs to be flushed and the collant replaced. The prestone flush kit is what GM recommends. Follow the directions, then replace the coolant. If you remain concerned about the headgasket, have it pressure tested bfore you do the flush.
Old Apr 3, 2005 | 02:50 PM
ULTIMTEORANGESS's Avatar
dexcool will do this if its exposed to air.
just clean out your tank and refill it.
Old Apr 4, 2005 | 01:57 AM
tombodad's Avatar
Thanks for all your help guys. Flushed out the system with water today, then i am running some Prestone radiator cleaner stuff for a couple days, before i refill with coolant. Still seems weird to me about the coolant. It was nasty. I had to use gas to clean out my reservoir, it was so bad. (dont worry, i rinsed very well) Anybody know where to dispose of used coolant?
Old Apr 4, 2005 | 06:22 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
*cough* storm drain *cough*
just kidding...
i think autozone takes used coolant just like oil...
Old Apr 4, 2005 | 11:11 AM
just kidding...
Neighborhood strays.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
