going to pull engine. need advice please
Old Sep 22, 2006 | 05:09 PM
mvvette97's Avatar
Never done this on an LS1. Is it a bitch to do? Will it come out of the top? I'm not looking foward to this
Old Sep 22, 2006 | 05:17 PM
iamsickofitall's Avatar
Re: going to pull engine. need advice please
i've seen pictures of it coming out from the top, but it was DAMN SNUG coming out. most people drop the k member and take it out from the bottom...you need to make some custom jack stands to get the car to sit high enough tho
Old Sep 23, 2006 | 08:06 AM
AL SS590 M6's Avatar
Moderator
Out the bottom is the way to go. And you don't pull the K-member then the motor. You pull the K-member with the motor on it.
There are some on line guides that I've heard of but I don't know where they are.
Old Sep 23, 2006 | 03:19 PM
i didn't think i implied that
Old Sep 23, 2006 | 06:25 PM
Bayer-Z28's Avatar
Would be easier to do w/ a lift, I immagine. Disconnect everything, then raise the lift and the engine SHOULD stay on the cribbing..
Old Sep 23, 2006 | 07:15 PM
WS6NIGHTMARE's Avatar
Personally Ive never dropped it out of the bottom. Ive always done it through the top, and once without even taking the hood off. Through the top the must have tool is the engine tilter, otherwise it aint gonna happen.
Old Sep 25, 2006 | 02:52 PM
chevy qc's Avatar
Mine was removed through the top without using a tilter.
Old Sep 27, 2006 | 05:44 PM
mook99TA's Avatar
I have done it both ways through the top and bottom. I have done 5 total first one through the top and the rest through the bottom. Bottom is the way to go.
Old Sep 30, 2006 | 01:53 PM
Doc99SS's Avatar
Dropping it out of the bottom is slick, but you need a car lift. W/o a lift, you gotta pull it out of the top, remove the hood.
I did it by dropping it out of the bottom, using a car lift at a friend's car shop. The car tied up the lift for 5 days. Fortunately, he operates a 3 bay shop.
Old Oct 1, 2006 | 09:40 AM
Moderator
You don't have to have a lift for out the bottom removal. You can put the rear axle up on large jackstands or crib up under the rear tires then lift the front with a chain fall or engine hoist (cherry picker). Buddy in GR has done it this way half a dozen times. If you do a web search I'm sure that you can find a link to his writeup.
Old Oct 2, 2006 | 10:44 AM
Eric@Victory Racing's Avatar
Write Up
F550maranello2
Apr 1, 2015 11:10 AM
transam_388
Mar 15, 2015 11:53 AM
David Dorris
Jan 17, 2015 08:10 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
