GM's new LSX block
How much is this new block? http://www.texas-speed.com/shop/item...d=708&catid=20 Is this it?
Yep.
The LSx motors are truly THE pinnacle of GMs SBC design.
There should be no reason why a motor with 50+ more cubes, better heads, and a bigger hydraulic roller wouldn't make 50+ more rwhp than I currently am.
As far as FI vs carb, obviously the nod goes to FI, but there's nothing wrong with a carb (besides gas mileage) if it's setup correctly.
Mike
Mike
I'm use to the old SBC. I built one about 13 years ago and it only had about 400 hp on pumped gas. 9.5 to 1 and a performer RPM cam and intake. I love the new LS1 and all the potential I have been reading about. Do you have a build sheet or recommended parts to get to build a hot LS1. thanks again for all your help
Craig
Craig
Mike
Craig
Craig
You can take an otherwise stock motor and do a top-end build on it by tossing on some ported LS6 heads or aftermarket heads like the new Trickflow 215cc heads, Dart 225cc heads, or AFR 225cc heads; a hot cam like the Futral Motorsports F-14, and the FAST 90mm intake manifold and LS2 90mm Throttle Body.
If you want to see what parts went into my build, you can click on my sig.
Mike
