which gaskets ?
Old Feb 19, 2013 | 07:12 PM
brock2k's Avatar
which gaskets ?
Soo i'm 98% done buying all the parts i need for my H/C/I build. Here's my list of what i bought and what i have on the car now. that will let you know which gaskets i should get.
what i bought: Llyod elliott LE2 Cam and heads 223/227.610/.614 112 LSA and the heads are .02/1.60 valves
Patriot Gold Dbl springs, Ti retainers, locks and locators
custom valve job
mill, cleaning and assembly
flow about 305/220 heads i bought are 243's btw.
ls6 ported oil pump, ls2 timing chain, ls7 lifters, ls6 intake, ticks master adjustable,gm slave. monster stage 2 clutch. plx wideband.
what i have on the car now: tsp 1 7/8 longtubes, egr air and pump delete, ported throttle body, slp air lid, slp lm2 catback, ory pipe. and hp tunner work done to it.
I'm keeping the stock injectors, unless the duty cycle exceeds 80-90% the rockers that came on the 243 heads i will use.
Now my question to all of this, is the gaskets, i narrowed it down to where im getting them and my options but i'm not sure which to choose from i have a link for it. and my very last thing i need i have to wait till i tear the top end off to figure it out, i need to get pushrod lenght checkers and then i will get hardend pushrods once i findout the correct lenght.
Basic Heads & Camshaft Bolt & Gasket Kit
which size gaskets and what lenght bolts ?
Old Feb 21, 2013 | 06:12 PM
brock2k's Avatar
Re: which gaskets ?
bump
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
