Front suspenion issue
Old Feb 24, 2004 | 09:41 PM
RxNupe's Avatar
Question Front suspenion issue
During a snow storm, I spun out and hit the curbside from the front of my vehicle. Afterwards I had a harsh grinding noise from the front (especially when I turn to the left) and it drove like a tractor. I continued to drive and noticed 1 month later that my front tires were wearing down unevenly. There was excessive wear on the outer edges. Yesterday I got a wheel alignment and new tires for the front...however the grinding noise is still there. The drive is still pretty ruff. The only differance now is that I have to get up to ~50-55 mph to hear the noise. What else should I check? Could a suspenion part be bent?
Old Feb 25, 2004 | 10:33 AM
Zdriven's Avatar
RxNupe,
Probably not a damaged steering component, most alignment
shops won't work on a car with bad parts.
You might have damaged a wheel bearing, depending on how hard you hit.
Old Feb 25, 2004 | 05:31 PM
RxNupe's Avatar
What goes into repairing a wheel bearing?
Old Feb 26, 2004 | 04:46 AM
Zdriven's Avatar
RxNupe,
sent you mail.
Old Mar 6, 2004 | 12:06 AM
RxNupe's Avatar
Ok....replaced the wheel bearing on the side where I hear the noise the most which was the left. When I jacked the car up, I spun the wheel (left side) and it didn't move as freely as the right side so I figured maybe the left bearing is bad. Got every thing done...went out on the interstate...everything was fine...until i got up to around 60 mph. The noise came back on the left side again. It's no where near as bad as it was but it's there.
Could I have a bent wheel perhaps??? Should I swap out the right bearing as well??? What else could it be???
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
8T8IROC
Mar 26, 2015 09:02 PM
Snoman73
Nov 17, 2014 07:22 PM
