Free Ram Air... The Truth Please!
Old Jan 16, 2003 | 08:06 PM
  #16
birdblack's Avatar
I've been wanting to perform the FRA but haven't quite found the time. I've even bot the Dremel. New Years Eve I spent in Tampa and got caught in a 6-7" downpour. Has anyone with the FRA driven in a downpour? Did it suck any water into the engine?
Old Jan 16, 2003 | 10:41 PM
  #17
StylezZ28's Avatar
How do u do the FRA mod? any sites that can explain?
Old Jan 16, 2003 | 11:06 PM
  #18
SpecForceZ28's Avatar
http://www.installuniversity.com
also has more free mods you could do to your car. nicely done with pictures and everything. enjoy
Old Jan 16, 2003 | 11:08 PM
  #19
Damn 6-7"
I wouldn't even drive it with that much downpour, but just drive slowly on puddles, and you shouldn't have any problems.
Old Jan 17, 2003 | 07:05 AM
  #20
birdblack's Avatar
It wasn't by choice that I drove thru that downpour. The Formula usually only comes out when the sun is shinning. That was only the second time it's be rained on. As I am planning to do the FRA my question came to mind as I drove thru the rain trying to get back to the motel.
Old Jan 17, 2003 | 08:37 AM
  #21
tomslawsky's Avatar
I drove from St. Pete to Lakeland, through Tampa that night with NO PROBLEMS. I have SLP cold air and a lid. Driving a Z in that weather sucks, but I just locked it in 5th or 6th gear and took it slow. The Stock GSCs seem to get pretty good rain traction, if you drive cautiouslly in the rain, I don't think these cars are all that bad....knock on wood
Old Jan 17, 2003 | 09:57 AM
  #22
birdblack's Avatar
Wasn't that quite a rain! I too was pleasently surprised the way the Formula handled. I was probably the slowest car on I-75 that night thinking I'd be the first to hydroplane but after a few miles I found myself moving with traffic and the Formula never twitched. I have a question about your SLP CAI. Did you do the FRA and then add the CAI at a later date? I was wondering if the hole I cut for the FRA will be the same hole I will use when I install the CAI later this year.
Old Jan 17, 2003 | 12:27 PM
  #23
tomslawsky's Avatar
In a word...YES, doing the FRA is the first step in adding the SLP. All you need to do now is to slip the duct down into the area thet you've cut out...simple!
Old Jan 17, 2003 | 12:56 PM
  #24
Serial Thriller's Avatar
I recommend the FRA mod because even if you decide to buy one of the induction kits later you'll have to do it anyway.
Old Jan 17, 2003 | 09:07 PM
  #25
blacknight's Avatar
Originally posted by psychocabbage
just use the stock filter.. you arent gaining anything but a cleanable filter.. if you want a filter that offers the same reuseablitiy get an Amsoil.. Its 2 stage foam.. But I have the filters and will still use the Stock paper just cause it does make more power..
I dont really care about reuseability.. if I cant afford a paper filter every 15-20K miles then I have bigger issues...
With the ram air you need to clean the filter about every 1500 miles so a resuable filter is the way to go. More power with the stock filter? What you been smoking boy?
Old Jan 17, 2003 | 09:25 PM
  #26
SS1LE02's Avatar
I've been hearing that the stock ones make more power. What's up with that. Anybody got any links to dyno numbers.
Old Jan 17, 2003 | 11:48 PM
  #27
Data's 2001 SS's Avatar
You won't see any gains except for the amount of dirt on your filter from this. You already have cold ram-air induction. Most of the replies to this post are from guys with Z28's - they're going to see a slight gain, but U won't. I recommend you spend your time elsewhere in your project.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Viper
Jul 30, 2002 02:06 AM
