Free EGR mod question
Old Mar 17, 2005 | 01:38 PM
twocam99's Avatar
I did this mod when I changed out my plugs 2 weeks ago, an now the car seems to hop/lop when driving at about 40, its kinda skips, but when I step on the gas it runs ok after a second, would cutting the end off that sticks into the intake make my car run like crap? Any one have an issue with their car after doing this mod?
Old Mar 17, 2005 | 01:56 PM
FastrDamnit!'s Avatar
Re: Free EGR mod question
Did it, and noticed no difference good or bad.
It's a really easy mod and from looking at how it sits directly in the stream of air, removing it should help, but probably no more than 1 or 2 hp I guess...
Old Mar 17, 2005 | 02:26 PM
PAGregSS's Avatar
Sounds like you have a vacuum leak around where the egr goes into the intake. That'll cause the symptoms that you're describing.
Old Mar 17, 2005 | 02:39 PM
2001NBMZ28's Avatar
Yep, check to make sure the EGR pipe is seated properly in the intake. My buddy didn't have his sealed right and threw an SES light.
Old Mar 17, 2005 | 08:19 PM
99Blackt/a's Avatar
Im going with everyone else sounds like a vacum leak check the egr where it connects into the intake make sure the oring didnt get pinched
Old Mar 18, 2005 | 11:35 AM
twocam99's Avatar
Yep, thats what it was, it O-ring, didnt notice it the first time. but when I took it apart, there it was pushed all the way up. Adjusted it and problelm solved. thanks everyone who had input into my problem.
Noenav
Mar 1, 2019 07:38 AM
HectorM52
Jul 30, 2017 11:46 AM
Jan 13, 2015 09:52 PM
cmdeshon
Dec 27, 2014 10:06 AM
High HP TA
Sep 6, 2002 08:00 PM
