folks i need some help!
Old Dec 2, 2008 | 10:08 PM
bil1965's Avatar
Unhappy folks i need some help!
hello one and all, just found your site and now i need your help. I have a 2002 trans am ws6, i have put pacesetter Longtubes with a hi-flo cat and 3 inch pipes on the car. my problem comes from the car sputters and acts like it is bogging down and i have to push the car to 2-3 grand rpms in order to get it up to speed. what can cause this issue?
Old Dec 3, 2008 | 04:11 AM
IXLR894Z28's Avatar
Did you have it tuned after install? Are you throwing any codes?
Old Dec 3, 2008 | 06:16 AM
johnny6's Avatar
Sounds like an o2 sensor issue. Take it to autozone and get it scanned.
Old Dec 3, 2008 | 10:46 AM
81noscamaro406's Avatar
Did you remove the plugs when you put on the headers? If not you could have accidentaly cracked one on installation and it would cause it to do that.
Old Dec 3, 2008 | 09:04 PM
Chrome383Z's Avatar
Untuned it should not run /that/ bad.
Plugs, cracked spark plug, 02 sensor; could be a number of things.
Are you getting a check engine light?
Old Dec 4, 2008 | 02:01 PM
Also check to make sure you didnt accidentaly plug the 02's into the rear plug ins.
Old Dec 11, 2008 | 08:22 AM
Kraest's Avatar
Retired
You need to have it scanned. Installing those parts definitely will not make the car do that.
Fatdog2
Sep 26, 2015 12:06 AM
LazyLemming
Aug 29, 2015 07:36 PM
Rittmeister
Aug 7, 2015 01:13 AM
meissen
Jun 1, 2015 07:59 AM
steve_c
18
Aug 23, 2002 03:49 PM
