First Tuneup for Z28's LS1
Old Jan 4, 2006 | 12:54 PM
Trainman45's Avatar
Happy New Year All -- I purchased my first Z28 in March 2005; it now has 50,000 miles and no documentation of tune-up. Have switched oil to Mobile 1syn, stock airfilter to KandN, and stock air box to SLP. Muffler swapped out to Magaflow. Otherwise all is bonestock. Question is: Am I ready for first tune-up at 50K or not? MPG wise I am getting 19 to 22 in everday daily driving and 23-25 on highway. Are some plugs better than others? Any thoughts would be be appreciated by this Camaro newbie.
Old Jan 4, 2006 | 01:00 PM
V8 Slayer's Avatar
Re: First Tuneup for Z28's LS1
AC Delco plugs
New set of wires
Fuel filter
pcv valve
Run some techron through the tank
Old Jan 4, 2006 | 01:01 PM
JakeRobb's Avatar
Super Moderator
Those MPG numbers sound fine, assuming you're in an A4 car (automatic transmission). If you're in an M6, you should be getting a little better than that on the highway (25-29).
A tuneup never hurts. Pull the front plug on the driver side and have a look -- if it's fouled, you should probably change them. The rear two on the passenger side are a pain in the *** -- good luck! I'm not sure if there's a particular brand of plugs or wires you should look for -- mine are still stock.
Welcome to the boards! Enjoy your new car. I got mine in August '05 and I'm sure looking forward to the spring thaw!
Old Jan 4, 2006 | 01:07 PM
Trainman45's Avatar
Originally Posted by V8 Slayer
AC Delco plugs
New set of wires
Fuel filter
pcv valve
Thanks for tips -- I'll see what my mechanic says --main thing I was worried about was mileage. Have heard that 100,000 was doable but I'd rather be safe than sorry. Afterall, I got one of the last Z's ever built.
Old Jan 4, 2006 | 01:10 PM
Trainman45's Avatar
Smile Re: First Tuneup for Z28's LS1
Jake--thanks for the tips. Appreciate them. Yes I have a A4 car with 273 gears and drive tame (most of the time ).
Old Jan 4, 2006 | 02:01 PM
teke184's Avatar
i've changed spark plugs on 2 cars, a 96 LT1 and my 99 LS1...both had ~50K miles.
both had the platnum puck missing from 4 of the 8 plugs!!!
GM is full of it when they say the plugs are good for 100K miles!!!
if the wires are in good shape, not cracked and are not arching (look at them in the dark) than you really don't NEED new wires. but it can't hurt. check out the Taylor Spiro Pros, they are good wires, and are only about $45 from any of the site sponsors.
wouldn't hurt to run some seafoam through the engine, gas and oil. do a search on how to do it.
i would suggest changing the trans and rear end fluid....just so you know they are good and when to do future changes. may as well get everything starting at zero so it's easier to keep track of
Old Jan 4, 2006 | 02:16 PM
2000GTP's Avatar
My friend has the Taylors on his car and loves em. He also used NGK TR-55 plugs this time around as well and he like his setup overall. Not to mention he also saved a few bucks over the stock Delco plugs/wires.
Old Jan 4, 2006 | 03:56 PM
Trainman45's Avatar
Thx Florida Z man. Pix look good. I'll alert my mechanic to look at plugs and possible missing parts.
Old Jan 4, 2006 | 03:59 PM
Kataklysm's Avatar
Most people use NGK TR-55 plugs or AC Delco Platinums. For wires MSD, Taylor or stock work best as well. 100k is to long so just check up on, if the car isn't misfiring then really no reason to spend money on it.
Deadbolt24
Jan 19, 2015 01:29 PM
DrMilhouse
Oct 2, 2002 05:03 PM
DrMilhouse
Aug 6, 2002 08:45 PM
DrMilhouse
Jul 19, 2002 12:52 AM
