First mod. Need suggestions.
Old Nov 11, 2003 | 01:14 PM
camaronewbiess's Avatar
Hi, It is my first time here and I just bought a 99 camaro ss. I was wondering what my very first mod should be. I hear a lot of talk about one mod not being able to work to potential without another one done and so forth. So i was wondering with a plain stock camaro ss what is the first thing you would do? Thanks a lot.
Old Nov 11, 2003 | 01:19 PM
NEWBIE T/A's Avatar
Thumbs up Welcome aboard !!
Nice year SS, BTW !
Is yours Pewter ? Sorry - I only answer questions asked by Pewter '99 owners - you'll have to go to another department otherwise.
J/K !
Your best bet is to read thru here:
http://www.installuniversity.com/
They have some great articles.
Free Ram Air is a good one, but you may not want to do that to your car - ?
I'd say go for the throttle stop mod, a lid, and the EGR mod.
Happy modding !
Britt
Old Nov 11, 2003 | 01:22 PM
hey thanks for the reply...i'm not ready for free ram air yet. Gonna keep it clean for a little bit yet heh. btw..how do you guys find the number of the ss i see everyone with like 99 ss # 1234. Thanks ill check that site out btw.
Old Nov 11, 2003 | 01:27 PM
foff667's Avatar
i think you can call slp for your #...if you have a stick car id say go with some long tube headers and off road y pipe...if you have an auto id say get a 3500-3800 stall converter as your first mod as a converter will gain you around 3-7 tenths depending on traction the headers will e worth probably 2mph in the 1/4 mile and depending on the brand you go with they can be really good bang for the buck...with a manual car and lt's you would be close to 110mph in the quarter right off the bat.
lata
Bill
Old Nov 11, 2003 | 01:31 PM
oh thanks, yes i forgot to mention it is a stick. I was also seeing a lot of people with K&N FIPK would this be a good idea too? or should i hold off on that?
Old Nov 11, 2003 | 01:35 PM
Waroo's Avatar
I just installed my air-box lid last weekend. It was a quick and easy mod, that would be a good start. I went with SLP's air-box lid, but no matter which brand you go with, they are about the same. Sorry, I don't know too much about the FIPK, but I do know you can install either that or the air-box lid (one or the other).
Old Nov 11, 2003 | 01:43 PM
Ken S's Avatar
since its a manual, if you still have the stock shifter, I'd recommend replacing it with a nice aftermarket one.... Like Pro 5.0 or ripper.. (don't bother asking which one is better)
The stock shifter has a rubber isolator, and the stick itself made of rubber.. its quiet, but feels rubbery..
that and the skip shift elimintaor, if its not already done.
Old Nov 11, 2003 | 03:24 PM
psychocabbage's Avatar
mods? do yo uwant per formance or what?
see, all too often people think "got car, must mod" and they dont think of why or what they are wanting out of it.
do you want more power? how about faster 1/4 mile times? or perhaps lower autocross times? Maybe you would prefer looks and appearance over performance?
You should decide what you want before hand then make the proper map to acheive your goals.
I prefer quicker 1/4 mile times with some quicker lap times so for me, I tend to mod more towards the handling more than the engine.. So far I am still stock but my other Z before was not.
The following are just small mods that are by no means meant for going all out.. just meant as a guide as to where ya may want to start.
So quickies:
1/4 = lower control arms, panhard rod, ES torque arm bushing, ES tranny mount, air bag in right rear
autoX = front sway bar, strut tower brace
power = lid, catback or cutout, maybe headers
appearance = ? I have no idea cause I dont care about this one personally. hehe
In any case, you should get a baseline dyno.. Stay tuned to your local car scene and find out when a car club is having its dyno day and see if you can get your car run. then when you do mods (at least when I do mods) add the cost of a dyno session in so you can see if you are getting anything good out of it. I always find that when you dont go to dyno days, the cost difference between 3 runs and an hour dyno rental to be less than $50 so I just get it for an hour and run alot to get averages.
Old Nov 11, 2003 | 05:11 PM
Carlos01SS's Avatar
If you want a better handling car, either straights or corners, get subframe connectors, this should be your first mod...
Ask which ones, you'll get about 5-7 choices, either weld-in ones or bolt-on ones, either way, your car will definitely benefit from SFC's.
Old Nov 11, 2003 | 05:22 PM
Knowklew's Avatar
Full Exhaust:
Headers, Ypipe, Cats, Catback
Then !CAGS, New shifter, Lid, SSRA, Swaybars, SFC's
Old Nov 11, 2003 | 06:29 PM
true... i forgot about those... i prefered the weld on..but its hard to find a shop in some areas where they will do it and do it right.
68camaroboltz
Oct 5, 2015 01:46 PM
thenewkid
Apr 12, 2015 07:42 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
92ragtop
Dec 27, 2014 01:56 PM
ajprengler
V6 Tech
Aug 5, 2002 03:26 PM
