Fast LSX Intake Manifold
Old Apr 8, 2006 | 08:13 AM
  #16
AL SS590 M6's Avatar
Moderator
Re: Fast LSX Intake Manifold
Originally Posted by Z28XTC
So the 90/90 makes the same as the ls6?
On a stock motor yes. Once you open the motor up with heads and/or cam then the 90/90 set up will start to pull away.
Old Apr 8, 2006 | 09:57 AM
  #17
Z28XTC's Avatar
thanks good advice
Old Apr 8, 2006 | 01:08 PM
  #18
Tuffguy610's Avatar
Yes I suppose that one day I will pick up an LS6 intake manifold. Thank you guys.
Old Aug 29, 2006 | 08:57 AM
  #19
350 HRSS's Avatar
Sorry to bring up this thread again....it just had some interesting points. Some are saying w/ a mild cam that the 90/90 set up would be alright and they wouldn't lose power. Is that true?
Or would the 78/78 set up make more power, w/ less chance of losing power,
with the mild cam, i.e. ls1 hot cam?
Thanks...
Old Aug 29, 2006 | 02:18 PM
  #20
myslowcamaro's Avatar
Thanks...
with a mild cam, i think it may about the same with the 78 or 90mm so in that case, just spend the extra $ and get the 90. you will be go to go on future mods then, otherwise save some money and get a used ls6 intake
Old Aug 29, 2006 | 02:36 PM
  #21
350 HRSS's Avatar
That is what I was kinda of thinking. If I was going to spend out the cash, why not go ahead and get the 90mm.
But I do NOT want to sacrifice any low end b/c of it.
The car is tuned by CAM for the LS1 hot cam and all the other mods I have. So the 90/90 wouldn't require tuning?
It's about $20 extra for the 90 tb over the 78 tb. It just doesn't make sense any other way.
Has anyone else ever did the 90/90 combo w/ a mild cam and bolts ons, and lost power????
Old Aug 29, 2006 | 08:29 PM
  #22
teke184's Avatar
here is some interesting reading on different intake options.
i realize it's kind of an ad for TPIS..but the info is interesting.
but on your mid cam...the $1200 you would spend on the FAST 90/90 would yield you about 5hp more in peak power than a decent ls6 intake. the power in the low end would be similar.
$300 for an LS6 intake and a 15hp gain....or...
$1200 for the FAST and 20hp....
i guess it's your call
Old Aug 29, 2006 | 08:46 PM
  #23
350 HRSS's Avatar
Does the BBK and Weiand intakes yield the same amount of hp as the LS6??
Thanks for the link teke184, I admit I did do a search before I posted and found that post.
Old Aug 30, 2006 | 11:28 AM
  #24
Kraest's Avatar
Retired
Ang,
I'd do the LS6 for a cam-only car and a 90/90 for a heads/cam car.
Mike
Old Aug 30, 2006 | 11:50 AM
  #25
teke184's Avatar
a test a few years ago between different intakes, on a 420hp crate LS1...
the FAST beat the LS6 intake by 1hp and only at the upper rpm range (only spun to 6400). while the BBK and weiand intakes both came out below the LS6. although something about the dyno graph indicated that the BBK and weiand would probably yield good gains if spun higher.
so again, the LS6 is your best bet
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
