explanation needed-idle quality
Old Feb 3, 2007 | 10:14 PM
maro z28's Avatar
Patrick G just explained that idle quality and lope are a result of overlap. More overlap, choppier idle. I thought idle quality was a result of EVO. I.E. an earlier EVO would result in a choppier idle b/c the sound of combustion was reverberated past the open exhaust valve and less muffling of its sound. How does overlap effect idle quality? Explanations appreciated. Thank you.
Old Feb 4, 2007 | 02:00 AM
Mean Green Z28's Avatar
Lower LSA (more overlap), nice lope at idle 'cos the car is basically trying to DIE at the lower RPM
Old Feb 5, 2007 | 01:16 PM
RE AND CHERYL's Avatar
The more overlap the cam has the worse the cylinder scavanging is at low RPM and the more exhaust is left in the cylinder. As Mean Green said. It's barely running and wants to die. This is why engines with real big cams have to have a higher idle.
Re'
Old Feb 5, 2007 | 03:56 PM
maro z28's Avatar
That explains it...thanks
Hal Fisher
Sep 30, 2015 09:03 PM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
